Removing old Whirlpool over the range microwave oven
7.7K views 2 replies 3 participants last post by  cat's_pajamas
If the front drops down and is loose you have to get under neath the rear and push up. it's probably on a plate that is screwed to the wall with a lip on it to hold the rear in place. sometimes it's not easy and you need two people to hold it. Make sure the range is protected or moved out of the way. I have seen many cracked glass cook tops from micro's dropped on them.
