Hi guys
Want to relocate the bottom left outlet to the big hole in themiddle of house. DoingT+G wall and want to hide the electrical.
Whats the safe way with regard to extending these wires used for the existing outlet another 6ft.
thx
A is the existing middle of run/ganged 2 plug outlet. The wires run down the bottom (see other pic) and my guess is into the master bedroom directly on the otherside of wall.
There is a single romex wire going through the joists where the larger red line is - I assume thats the feed wire to the bedroom that eventuall goes to the outlet at A ... or possibly it runs the other way to feed 1 or two more outlets on the other wall right of pic.
But goal here is to hide and relocate the existing outlet to the hole at B. Can I just get a protective junction box and two strands of ~8ft wire and extend ... and tie and secure in junction box with normal wingnuts ? Will be behind wall obviously.
eg something like ....
Finally ,........ ideally Id like to covert the 2 outlet to 4 outlet if possible ........... (TV, DVD player, soundbar, fireplace) ......... is that easy enough to do ?
I think my amps with the fireplace will be too high to run in heat mode .... but have a split unit so will just be using for ambience unless nothing else on circuit running.
Anyway - first question is to relocate the existing 2 outlet middle of run to the main hole ~8ft away.
thanks !!
thx
thanks !!
