My engineer spec'd normal footers and then sonotubes for my deck build. I am going to be using bigfoot and sonotubes to do a mono pour instead. I will be using a combination of 36" and 28" bigfoots.
How do I go about creating the rebar structure inside the bigfoot/sonotube structure?
I will be sinking Column Caps in the top of these posts. Can I make the vertical part of the rebar short enough so it does not interfere with the Column Caps?
