I just purchased a new oven and although the outlet and wiring is compatible, the location of the outlet makes the oven stick out from the wall because it sits high. If the outlet were lower, I could push the oven back further because there is open space in the back of the oven up to about 2' (the outlet is just a tad higher).
I would like to fix this, but I'm not really sure what to do. Is there any sort of recessed outlet box I could use? What if I use the current box as a junction and install a new box for the outlet? Is this code?
Thanks,
John
Thanks,
John
