question about electric winch
2.5K views 21 replies 14 participants last post by  Gregsoldtruck79
A small window air conditioner was installed over a door, where there was a transom window. I need to get this down and install a new one. Can't do this on a ladder anymore. So simple answer is a winch but never used one. My question is, as in the image, how is the wire rope kept from spinning free when the heavy object is coming down? Motor only?
Also, I was thinking of using the ratcheting strap. If the strap is wrapped one way only, I guess about 6-7 times around the ac (getting 30' strap), will the ratchet get all 6-7 wraps of strap to tighten around the ac?
Those winches are supposed to have auto braking , to prevent freespooling.
You will need to verify this before purchasing one, some manufacturers omit it to allow a cheaper unit.
What is the weight of the A C unit? an assistant would be handy, or more than one.
Whatever you do, do not get under it to lower it, if it comes loose, you will be harmed.
ED
Reactions: carpdad
#8 ·
Sorry no photo but it is above a door with a tricky location. The door is on a corner (wall on one side) leading out to a narrow (3') screened patio. 2 stories up. I also don't know anybody I'd be comfortable having accidents with.:smile:
Joe, I think I was planning myself into getting a new tool.:smile: Though I think this is the best option with nobody under the thing. I will be making the winch brace better than I described.
Thanks for all replies.
#12 ·
The lift cart type is the first thing I looked at but they tend to be heavy (have to go through the house, out to the bedroom patio), not very manuverable and for a single purpose. Same with the scaffold. Actually I had the words mixed up. The image is a hoist, not a winch. Found Champion hoist manual that clearly shows a brake. About the same price at homedepot. Wish I went to homedepot site also. Would have preferred champion that at least has an office and publishes a manual.:smile: Grainger also has a paper on the difference. Winch does not have a brake or has gears that may fail. Winch is not for verticle lifts. The amazon buyers seem to like it and use it to take thing up as well as down, so I assume it has some kind of brake.
I may return the amazon hoist if the manual is in chinese.:smile:
#16 ·
I saw another video somebody using a ladder to hang a hoist from. I think I came up with an easy to assemble brace. 2x4 legs (12' now - what I had) with 1.5" holes cut near the top. 1.25" metal rod through the holes and this will be set up with the legs splayed out and tied togther with 1x at the bottom. I'll put a brace across somewhere near the top too. I think this will give me a good lateral side brace to hang a hoist. Cross brace will be whatever fits.
For those ratcheting strap virgins:smile:. I tried wrapping the strap around a box then tightening it. The first layers don't tighten up like a rope does. I ordered multiple set.
#18 ·
If you could lift it out of a normal window then John's scaffold suggestion is the best. That particular model he pictured may not be the best choice since it almost takes 2 people to raise and lower the platform.
2 quality step ladders and a couple of 2x boards with a2x4 center support to the floor would support my big butt and any AC I wrangle around.
#19 ·
The wall right beside the door makes many of the options a little more difficult. Possibly best option is one strong fellow. But I can understand you wanting to DIY.
Best I can come up with is to buy a bunch of 2x4s, etc to make a structure to help you "step" it down and the new one back up. The lower "platforms" would need to be removable, because you probably want to be standing where the second step is, when you are pulling the AC to the first step.
