Hi folks. I’m new here and thought I’d share my in progress replacement of my PB plumbing with PEX-A. I thought I’d have a few years to slowly piece this together, but now 1 year into owning this house, I’ve already had two pinhole leaks in the PB. Now I’m racing against the clock before the next leak. Attached are pictures of my progress on the manifold so far.
As of now, I’ve run my 1” main, 3/4” to/from water heater, and all 5 of my 3/4” cold supplies (4 hose bibs with full port 3/4” valves and one for future expansion that will be capped off for now). Tomorrow I’ll get started on my other fixtures, all of which will be 1/2”. My goal is to have no fittings whatsoever between each manifold valve and it’s respective fixture. Additionally, I tried to design this manifold for maximum flow, and went with home run for the same reason. I figured if I’m doing all this work, might as well do it overkill!
