naomit111
Discussion starter · #1 ·
Hi, I was just about finished painting and only had the skirting boards left and when i pulled up the tape that i had lined the room with the gloss paint had somehow gotten through to the grout in the tiles. Can anyone tell me how to remove this?
Hey Naomit111,
chrisn is right a little Goof Off and a small scrub brush should work just fine. But keep in mind that it will also remove any type of grout or tile sealer you may have had applied previously so another application in that area is probably a good idea. Good luck if that doesn’t work let us know there a few other products that will get it out no problem.
