I want to take my semigloss down to eggshell. I was told I needed a special primer to adhere to the paint or to sand down or to use TSP.
I want to also repair the wall here and there with spackle. So the question I have is, can i skim coat over the semigloss or do I have to sand the wall or prime first?
FYI
On another wall I did some repairs with spackle, then primed it with a special primer; however with the primer I can still see where I spackled because those repaired areas are flat and have no texture, but the rest of the wall does have texture despite using a 3/8 nap roller.
I hope that:
1. The spackle will adhere to the paint
2. That when I paint over the other wall that has primer that the 3/8 nap will give the same texture.
FYI
I hope that:
