1 - 2 of 12 Posts
I considered that it was so well insulated, that it created a negative pressure, making it difficult for the portables to push enough air out of the building.
Why is your AC pushing air into or out of the building ? AC is normally a closed system.
Your insulation may be good, but not great. I have R70 over my head right now. But your HVAC guy should be able to run the numbers of what you need.
I have never used a portable air conditioner, but they don't sound like a good idea. If it is a single hose type, then for every cubic foot of air that it exhausts, it will suck in a cubic foot of hot outdoor air (that is basic physics, no way around it).
Portables don't seem to be very efficient. That may be part of the problem. http://www.budgetairsupply.com/budget-air-supply-blog/warnings-about-portable-air-conditioners/
Minimum code in my area was R-32 or R-35 when my house was built. I added 11" of rockwool bats (R-44) on top of that.
If none of the forum's HVAC guys chime in, you may want to post your problem in the HVAC area.
1 - 2 of 12 Posts
