Hi Everyone,
I have this weird set of double hung windows that goes down to the floor. I have a standard sized french door set with an full glass inswing door on the left (from the perspective of the photo below) and a full glass stationary panel on the right that I'd like to put in place of the window set.
The rough opening is something around 83", so I have to decrease the width by about 11 to 12" to accommodate the standard door size. The rough opening height seems to be okay.
The two aspects I was hoping to get opinions/ideas on are 1. how to decrease the width of the opening so that the final siding/door transition looks the best and 2. how to do it to maintain the best insulative properties.
Seems to me like the best bet is to split the ~12" difference between the 2 sides and then simply trim the new door with fairly wide (~6") vertical boards. In this case, would you stack ~4 studs to each side of the existing rough opening? Seems like a pretty poor thermal bridge. Make a box for each side with ~3" of insulation in between 2 single vertical studs?
I'm not totally against replacing the window set with something other than a standard door set, but I already have a standard door and I don't necessarily want to spend money for a custom fill.
Thanks for any ideas.
