My washing machine is leaking. I checked the drain plug and it didn't seem clogged but after I took the hose off water came out the drain and when I tipped the washer backwards water flowed out the drain hole where the hose goes. I then took the front of the washer and started a cycle. Water appeared to leak from the tub. Any ideas?
Am I better off just to get a new washer? It's only 2 years old. Before the water leak happened I was having trouble with it shaking during the rinse and clothes were getting knotted under the agitator and under the agitator wings.
Here's a link to a video showing the leak: https://youtu.be/j9RMjSjtOW0
Thank you,
Roses253
Thank you,
Roses253
