I think I finally fixed a leak in which my stucco house was leaking through a crack by the roof. I took out the sheetrock and pulled out some wet insulation. Part of the plywood has rotted (see attached picture). I am not sure if I need to fix it as it is only about a 2'x2' section that is rotted. I also beleive to replace it I will need to have the stucco removed first, which is very expensive. Any ideas?
Thanks!
Thanks!
