1 - 1 of 15 Posts
From your thread first post; "I didn't mention eves because they have soffit vents and running it out those would cause some of the humid air to come back in."--- good for you!
IMO, run some smooth wall out a ways, enough to add a 45* to get over the cj's, then another where needed to sit slightly higher than the termination hood- to allow condensate to drain to exterior. Though there shouldn't be much with the metal pipe encased in 4 or 6" HVAC flex duct, complete with vapor barrier plastic. Flex for piping has 2+ times as much area (than smooth pipe) for trapping wet air, coating the inside with moisture. Hence the recommendation to go one size larger for rated airflow due to turbulence created- without proper support, fully stretched or kinks/sharp bends; https://www.thefreelibrary.com/Pres...ure+losses+in+12",+14",+and+16"+non-metallic+flexible+ducts+with...-a0201591046
Terminate at least 3' from window openings or other house opening.
Gary
Reactions: Marky82
1 - 1 of 15 Posts
