I bought a 12 feet 6x6 pressure treated post for a clothesline (see picture below). It is in good condition (no major checking), but I will let it dry outdoors for a month before installing it.
I live in Canada (southern Quebec), cold/snowy winter and hot summer. I'm only an amateur and need advice, but my plan is to wrap it with a sleeve (like Postsaver) for extra rot protection at ground level and bury it 3 feet deep. A few questions...
1) Is it ok to use a 10 feet diameter sonotube or does it really have to be longer? Length of sonotube has to be 3 feet long?
2) Should add rebar for extra concrete strength? If so, how many?
3) Can I skip the sonotube and pour only 1 bag of concrete at the bottom of the post (above 5" of gravel) and fill the rest of the hole with compact soil? If I fill out the hole with more than one bag of concrete, I worry that it would be a hassle to remove the post in the future. It will probably require special equipment, etc. Is this method acceptable for clothesline post?
I would appreciate any other advice.
