Inground pool main drain leak
8.3K views 8 replies 4 participants last post by  SouthernYankee
I've had a polyurathaned/insulated hot tub with a minor leak...can't recall exactly, but enough to be a constant puddle on the decking....maybe an inch drop in full tub every several days or so.
Could not trace it with all the insulation.
I tried 3 or 4 brands of similar stuff (sort of like radiator sealer for hot tubs.)
Came in quart bottles and had to be dumped right into the full tub to circulate all the plumbing.
Took several weeks, but it finally curbed the leaks almost completely.
This was an investment/flip property of mine, and the tub had been empty for a long time. So I really don't know if it was a PVC piping leak or at some dried out grommets and washer etc within the plumbing and heating systems.
but if it were an unglued PVC fitting, seems to me the stuff would likely eventually seal up the leak.....if it was a cracked PVC ...I think it would work....but if it was a broken or hole in the pipe....I don't think it would work.
Good luck
