My wife said the bathroom smells like poop. Sure, enough it did. You could smell a slight sewer smell from an area where I removed a baseboard to install a cabinet. Then I got to to thinking, "did I screw that left lag bolt into the vent pipe?" Well, I think I did, because up in the attic, the vent pipe comes out of the 2 x 4 header about 10" away from where I screwed it in. I am guessing the vent pipe angles up the wall to move around a larger support beam. When I unscrewed the screw, it didn't have a pine smell on the end of it like the other screw.
How can I best fix this blunder?
Plumbers epoxy? I also read that you can screw in a stainless screw with silicone on it, but I'm kind of leaning towards not doing this.... This is a good size screw, about 3/8 in diameter.
Thanks for any help.
