Hello.
My current 4 ton unit (Trane XR13, Trane XR95 furnace and 4 ton coil) services the 2nd floor (~ 1100 sq. ft.) and 3rd floor (~700 sq ft.) in my home. The unit currently has 4 zones (two zones on the second floor and two zones on the third floor) with a pressure bypass going back into the main return plenum. The compressor is no longer functioning properly and the unit is no longer under warranty so I am going to replace it. In order to help with cooling the third floor better on hot days (third floor is hotter as heat rises and heat from the attic), I wanted to upgrade the unit to a 5 ton variable speed blower. The current duct work has four 10 x 10 returns, one 10.5 x 10.5 return, one 14 x 14 return, and one 8 x 8 return. In order to get the required 2000 CFMs for a 5 ton unit, I wanted to simply either increase the size of some the current returns or add an additional large return in the third floor hallway (calculations attached). My questions are below. Could someone please review and let me know their thoughts? I have mixed feedback from multiple contractors regarding using the current duct work (some are saying it needs to be completely redone) and the use of a variable speed blow with a pressure bypass (some contractors are saying this is not OK). Thank you.
1. Can the current duct-work be used and just add more returns to compensate the larger air flow of 2000 CFMs.
2. Can a variable speed blower be used on a zoned system that has a pressure bypass.
