1 - 5 of 13 Posts
Discussion starter · #4 ·
OK so what's a "comb fascia"?
They make post wraps that just snap together and just need to be cut to length, no screws needed.
If your trying to use PVC lumber, which would be a royal pain to do and keep lined up I be using these.
https://www.homedepot.com/p/FastenM...stenMaster-Cortex-75-Piece-Fastener-Set-for-AZEK-Trim-FMCTXT-AZ50TDHD/202502288
"Combed fascia" ....https://www.homedepot.com/p/Trim-Bo...Nominal-2-in-x-8-in-x-16-ft-Actual-1-375-in-x-7-06-in-x-192-in-696199/202180045
Discussion starter · #7 ·
the top and bottom collars is where the verticle structural stability comes into play.
to retain a constant distance between the wrap and the inner post,
you can tack a few pieces of 1/2 or 3/4" styrofoam spacers around the post.
(taking that additional measurement into consideration when
fabricating the wraps).
Can you explain how the collars add stability?
Discussion starter · #12 ·
We see all kinds of wrap , wood like the OP is doing to expanded size all the way ip to covered with stone. The wood of the wrap never touches the deck. Only the post makes it all the way to the floor.
For a simple wrap you can't beak plastic.
https://www.youtube.com/watch?v=ejeGnmcOYDQ
Hey NealTw, is there somewhere local that you get this product?
1 - 5 of 13 Posts
