Just removed a lot of blockage from my drain field PVCs after fixing a corroded septic baffle. Now I need to know if the perforated field pipes are draining properly. Is there a standard way to test this?
contacting the locals could create more problems than you know. Age and area have a lot to do with this. Be sure not to be in a situation where you give your name when you do.
Personally I would cover it up and use it. If you did not fix the problem it will surface quickly.
Mostly what I have seen is when the field is blocked by roots they require a new hunk of land for a new leach field.
Related Threads
DIY Home Improvement Forum
posts
3.4M
members
353K
Since
2003
