How to connect deck joists to posts?
23K views 10 replies 3 participants last post by  bryanf
The old rail posts were nailed to the outside of the joists. The corner posts were notched and attached to the outside of the rim joists and header joists. They were not very stable.
You are kinda set to go the same route with a set up you a dealing with right now ...
Make it stable this time...and run this by your building inspector , just to make sure it is approved in your area.
http://www.strongtie.com/products/connectors/DTT2.asp
