How do you feather edges of multi-layered latex on cedar siding?
1 reading
3.6K views 11 replies 5 participants last post by  mark sr
If you've scraped and pressure washed your cedar board and batten siding as far (or farther) than is safe for the wood but there is still thick layers of paint stuck, how do you sand so that it's not obvious through a couple layers of primer and paint? I've used my belt sander, orbital, hand planers and every grade of steel wool to the point where I now don't even know which worked best.
Here is a before pic... I'd take an after but I'm still traumatized by the whole paint removal trials and error and would rather regroup before looking at it again.
642227
#4 ·
What kind of paint is on the house now? Sounds like concrete. I mean, you should be able to feather with relative ease using an orbital sander. There's some elbow grease involved to be sure. It's best to start with a carbide (very sharp) scraper. Those things, if used properly, get an awful lot of loose paint off. Once that's done, break out the orbital and sand.
You might be overthinking this. I don't really see a bunch of areas that need much feathering. Looks like typical peeling paint. Of more concern to me, are the fascia boards. Some look like they've been replaced before. Check the drip edge to make sure it is installed properly. It should have a 1/4" gap between it and the fascia so water is shed away from the wood. There's also some areas (where it's peeling the most) where wood looks to be in contact with stone/concrete. That wood will wick moisture up into it and cause premature paint failure.
#9 ·
You have a very good eye, not only were they replaced, one of them seems to have been replaced with a board filled on one end with drywall. Not kidding. It was broken and hanging out of the board above our front door. My husband and I thought it was concrete stuffed in there but no, think it was drywall putty or something like that.
And you were right about me overthinking it. I ended up throwing caution to the wind, chalk painting my frontdoor a brighter red, and painting the horrid little shed (bought the stencil on Amazon) (no idea how they got those cinder blocks shoved under there but we store only enough to make the spiders comfy in there.)
Photo of house and shed
656936
BTW, we did paint polyurethane over the chalk painted front door and it has held up wonderfully. It's an old door that we're afraid to replace so all the imperfections were showing with the high gloss door paints I tried first. You can't mess up chalk paint, so I ignored the rules about inside outside use and did it.
