kimorajason
Discussion starter · #1 ·
You just sit back on your most favorite reclining chair and pick the remote up—don’t worry you’re not going to watch television but you’re going to talk about your pains and aches—and telling it to give you a massage.
But what if you want to shift it from one room to another? Then you should know how do you disassemble a massage chair!
The massage chair—also called robotic massage chairs ha, sit back put you chair ve been around for the past few decades.Continue to read go on recliner shunt.
Very old post but I just did one so interest here. I guess fairly high quality chair. Leather. Massaging is done with air bladders. A mass of wires, air hoses and bladders. Plastic and metal brackets to hold everything in place. Not just screws but interlocking plastics. Leather precisely punched, stretched and hooked into plastic hooks in the brackets. I would guess impossible to take them apart for storage. I was throwing out parent's chair that's not going to be used.
Moving a recliner chair isn’t easy, but if you take it apart the right way, it’ll be much more manageable! Start by checking the manual since each chair’s a bit different. Usually, you can remove the backrest and armrests, which helps a lot with lifting. Don’t forget to unplug any wires so nothing gets damaged. If there are any cushions or pads that come off, take those off too to make the chair less bulky. Once you have these main pieces separated, moving the chair will be a lot simpler—then you can set it up and enjoy your massage in the new spot!
