1 - 3 of 15 Posts
If you are not sure you can compact it good enough, cheat.
Drive 4 2x4 stakes down into the mud and cut them off at the height that will be the bottom of the concrete.
Bad idea. That assumes you want the 2x4 to provide some support for the concrete patch. Pretty good chance the wood will rot away. And unless you pound the wood down to a proper depth, it could also sink under load.
1 - 3 of 15 Posts
