Hello
I installed a Ranein Tankless Water Heater 18kw for my infloor heating system yesterday. It requires 2 x 40 amp breakers. The heater is just 4 meters away from the breaker box. I used the recommended 8/2 awg wires. My breaker box has a 200 amp service. If I understand it correctly, 18000 watts / 240 volts = 75 amp, which shouldn’t be a problem for my 200 amp service. I also checked all other higher amp services and made sure they are turned off.
But the lights in the house are flickering!!!
I googled the problem and found it is a known problem if the heater draws too much power for the breaker box (voltage drop), but this is not the case here.
Any ideas how to fix this problem?
THANKS
Gunnar
