1 - 5 of 20 Posts
I'm working in a fairly narrow dug-out channel next to the slab so the bending would have to occur beforehand. But could I install the prongs and then wire-tie lengths of rebar to the prongs, basically substituting short ( ~ 8 inch) epoxied pieces of rebar for the concrete anchor screws?
Yes, I have not used epoxy for that but it is the approved method just tieing it should be fine.
Why would you not trust the manufacture's advice? Have you measured the thread outside diameter? We have no idea what you have or what size the threads are.
The threads are bigger on those so you do drill 1/2" for a 1/2" bolt, I don't think he has them in hand.
1 - 5 of 20 Posts
