Hello all,
I'm trying to figure away to hang a door straight from the ceiling use iron pipe. The issue is attaching the pipe to the door.
I've found these connectors, the feet of a selving unit that that will take a 3l8 bott which I can attach to the door with a tnut. See pic. This doesn't exactly give me the look I wanted.
Is it possible to cut end of pipe and put a female
Or internal thread and attach the feet connectors directly to pipe. The pipe is 3/4 and the flange is 3/4 and iron connector is 3/4. If I were to cut a internal thread what size would it be. I found that the feet connector was too small to fit in the flange
Thanks any advice would be helpful
