Good day to you all. Nice forun you have hear. Took a look around and did not find what I am looking for.
I have a GoodMan Heat Pump 2 stage AC unit. Model # GPH1560M41. My thermostat is a Write Rogers Model number 1F83-277.
Last week an AC technician found the Run Capacitor had gone bad and I paid the labor to replace it. Part was under warranty.
He then checked the system by turning every thing back on. Things seemed to be fine for about 5 minutes... But he then spent about 2 minutes doing something with the thermostat. And then instead of cooling in cooling mode, the unit produced heat. No mater if set for heating or cooling.
He told me the t6hermostate had suddenly blown and gone bad and was not energizing the reversing valve.
He wanted over $300.00 for the exact thermostat, plus labor. I thought it was strange that the thermostat would fail like that, and his price seemed ... Well high. I told him I did not have the money to fix it right know. He told me he could "Jump the Reversing Valve" for now, but I need to replace the thermostat ASAP and to make sure I call him to do it, or I would have no heat in Winter.
He ended up telling me he jumping the Reversing Valve to keep it running in cooling Mode no matter what.
I called Wright Rogers and over the phone they had me trouble shoot the thermostat, with them on the phone and me pushing buttons and telling them what the read out was, per their directions.
We checked the configuration menu and the thermostat was now somehow configured as a multistage system, MS2. We changed this to HP2. But the only way to know if this fixed it is to undo the "jumper".
I contacted the technician and explained this to him. He told me he would come out and remove the jumper for $200.00 (normal "service call charge is $98.00), and then I should forget about ever calling him again.
I have searched the internet just to see what a Wright Rogers Model number 1F83-277 thermostat goes for. It is a discontinued model and I can buy one easily new in box for under $80.00 retail. Including delivery.
I did turn the unit off at the thermostat and disconnected the power at the roof top electrical box. I opened the unit, but I could not see what looked like a "jumper" wire to remove it. I would like to remove the "jumper" to see if it is the thermostat or not.
I do not have experience working on AC units. But I have worked on household power, and worked around 120 and 240 volt lines and know to always kill the power at the main, and then test to make sure it is OFF!
Any ideas on how to find the "jumper" and put it right?
I thank you guys and gals for you time and assistance on this.
