Hi all, I want to make a loft to store lumber over my garage door. I have around 800lbs currently, and want to have it up in the loft so I can pick through which piece I want without digging into a stack.
My plan was to use the LVL over the 16’ garage door as a sill, and come out about 8’. The length of the loft would be 12’. One side of the 8’ run would rest on the LVL to carry the load, but tie into the existing studs for stability. The other side of the run would need to be suspended from the rafters, whish is about 3’ above the top of the LVL. I woukd run OSB or similar across to make the storage ‘floor’
I’m trying to decide the right size for the floor joists (2x12? 2x10?) and how many 8’ runs I need to make to be safe. I’m also trying to decide the best way to tie the 8’ runs into the rafters. My plan was to take a 3’ board flush against the rafter and floor joist face, and use some lag bolts, but I’m not sure if thats the best plan (especially not sure about drilling holes in my rafters
Thanks!!
Thanks!!
