Garage door - can I replace "just" the actual opener?
1.5K views 16 replies 7 participants last post by  firehawkmph
Be VERY careful if you're dealing with the main door spring. Hopefully you won't have to touch that, and you shouldn't if you don't know what you're doing.
I personally also like the belt drives.
colby has a point about having a helper, although I've installed them fairly easily by myself - but then I'm using to installing ceiling light fixtures and stuff like that.
I personally like to oversize if there's no major cost, if only because I think the motor will have less stress and last longer. The drop in sound between a chain drive unit and a belt drive unit will more than make up for any change in sound to a more powerful motor, if there is one at all, which I doubt there would be.
