I installed an external 15A GFI outlet controlled by a Lutron Caseta smart switch. In one of the receptacles our LED holiday lights are plugged in — it all works exactly as expected.
Next I plugged in a Hampton Bay landscape transformer into the other receptacle. Yard lights came on so, I thought I was home free. I turned the outlet off via HomeKit and then back on, and the GFI tripped. This happens every time — even when the transformer isn’t actually attached to any lights. (I get that the secondary shouldn’t affect the CFI, but I thought what the heck). If I turn the outlet on, unplug the transformer, then reset the CFI, then plug the transformer back in, it works. Switch it off and then on again and the CFI is tripped.
Then I plugged the transformer into another Caseta-switched outlet inside, and it works perfectly. The only difference I can see is the GFI.
This doesn’t seem like a complicated scenario, so I’m at a loss. Is the transformer drawing a lot of current when it starts? If so, why doesn’t it trip the GFI when I plug it in?
Thanks for any advice. Circa 1985 wiring, with neutral.
