Good Day All
I just recently purchased my first Graco sprayer. It is the Ultra Max 2 490 with a contractor 2 gun :thumbsup:. I purchased it used and keep in mind I still have a 30 day money back guaranty. When I bought it there was, what I believe, to be paint thinner all through it. So I brought it home and ran gallons of water through it and some pump armor.
Now, this sprayer looks like it has pumped 100's of gallons of paint through it. So I decided to take it apart. In doing so it is quite obvious I need a gun repair kit, no big deal it is to be expected. Although, I noticed some rust in the ends of the hose and the base of the Spray gun. Is this fine? Do I need a new hose? or is there a trick to clean it out. Furthermore, when I took the gun off the hose to flush out the hose when I turned the priming switch to prime there was water coming out the hose. Is this normal?
Next, I took the pump all apart and inspected it. All the throat seals are deformed and looking like
. I need a pump repair kit now as well. However, when going through all the pieces there was rust in the main pump housing and the piston is all rusted as well which doesn't come with the the pump repair kit. Should I get a new pump? or pump repair kit?
Also, In the hose leading from the pump to the filter there is rust in there and also a little bit of rust in the filter housing.
The last problem is of the two bolts that attach the filter to the motor hosing one is stripped so I might be able to use a tap and die set on it. The other is unable to go in because it is broke right off and is being supported by a wire.
The big question is to put it all back together the way it is and get my money back :furious:. Or, do I send some money get all new pieces and spend the time fixing it up? Which pieces would I need? can I clean some of the rust off?
Any help would be greatly appreciated.
F.Y.I - I payed $400 CAD for it :thumbup:. I could probally buy it brand new around here for $1600 CAD, I have seen other used ones for around $1000 CAD on KIJIJI in my area. Also, there are some sprayer rescue shops in the area. Edmonton, Alberta, Canada
Thanks for your help and time in advance
Scott
Scott
