Drilled out hole in concrete too big for tapcon screw
1 reading
26K views 38 replies 13 participants last post by  RoofGator
There is an epoxy made for this very purpose. I used such an epoxy to anchor my shed. The strength is rated greater than the concrete. Just look for concrete anchor epoxy (or something like that). Then fill the hole with the epoxy and then you can push a bolt into the hole and wait for it to cure. Then you can use a nut on top of the bolt. You may need to actually make the hole even larger and find an appropriate bolt.
