Double Door Alignment Advice Needed
42K views 6 replies 5 participants last post by  Gary in WA
the leg is the side of the frame and the head is the top of the frame.
the doors being out of plane: are they warped in a way that would cause that?
btw; you put molding around the frame to cover a gap that is there on every framed door. That gap is where you would place the shims to plumb, level, and square the frame.
If it were me, I would remove the frame and start over. It looks like the frame on the left is bowed in in the middle so if you put a 3rd hinge on that door, you will have problems.
