Door Swing Space too Small
5.2K views 17 replies 9 participants last post by  Nealtw
Moving the door and hinges outboard, as suggested in Post #2, should get you most or all of the needed clearance. If you still have some interference, you can either shorten the door a little, or cut the corner as shown below. If you cut the corner, put a filler block in the door jam, and you will hardly notice it.
