Hi, we have a double front door on our house. The left door (from outside) is fixed with upper and lower vertical bolts. The active door is problematic…
the bottom corner of the door where it meets the fixed door doesn’t close properly. When you look at it from the inside, it is not flush with the other door and leaves a big gap.
i can’t see anything physically preventing it from closing more. I can push on it with my foot and it will close further (also pushes the dead latch into the strike). The top of the door seems flush and around the sides everything seems like it should.
Is it possible the bottom of the door is warped? Or is something out of alignment?
