When tackling a DIY project, does the brand name of your tools and supplies matter to you? Why? Why not?
What about the retailer? Is it important? Which home improvement store do you prefer? Why?
For work, you might use the same tool everyday for hours. For DIY, you might use the same tool once or twice a year. However, for the tools you use often, like a screwdriver, a drill, ya, get durable, because when they break you have to stop and go buy a new one. I find the cheaper tools often have a weak link, like a switch, or the electronics board, or a small plastic keeper..etc.View attachment 851263
Sounds similar to mine.I Use a I do not know the age Craftsman table saw, still accurate!
Changed to a segmented belt , less noise and added a large kill switch right on the front. Mounted a router on the left wing ,which i replaced with a solid top with tracks and a adjustable rear fence
I agree that for some tools, one should buy the best quality they can afford.Buy once cry once. I have learned that no matter what the tool quality is the way to go.
Curious what you and clamping that you are needing so much force to deform the clamps.I agree that for some tools, one should buy the best quality they can afford.
IMO, they does not apply to all tools. I have numerous bar and f-clamps all purchased from Harbor Freight. Granted the bar clamps are extruded u-shaped aluminum and tended to twist a bit when tightened. However, the addition of a piece of 1x2 in the channel makes them surprisingly robust. I have used them for years with no issues. Additionally, I was able to purchase four 4ft clamps for the price of a single Bessey brand.
I also have 4 of those clamps [2-4' and 2-3'] but have never seen the need to reinforce them.have numerous bar and f-clamps all purchased from Harbor Freight.
These bars are u-channel extruded aluminum similar to this. Sometimes you have a board that is a little stubborn. It is these where the aluminum can twist a bit..Curious what you and clamping that you are needing so much force to deform the clamps.
If I have something that needs 'encouraging' to line up my go-to is pipe clamps.These bars are u-channel extruded aluminum similar to this. Sometimes you have a board that is a little stubborn. It is these where the aluminum can twist a bit..
I do own a pair of vintage bar clamps similar to this. They are about 5ft long so using them on smaller projects can be problematic.If I have something that needs 'encouraging' to line up my go-to is pipe clamps.
If my P-C ever bite the dust, I will likely go with Ridgid. I have their cordless impact wrench and oscillating multi-tool along with a corded 14-gal wet/dry vac. All have served me well.Many years ago, (25+), I bought a RIDGID combo set at Home Depot to replace my dying makita tools. I chose these because of the lifetime warranty.
Problem with the warranty service is that the location is far from me. But they serviced my drill and charger just fine.
Found out that if you buy a RIDGID tool from AMAZON; RIDGID will not give you the lifetime warranty. You have to get it from Home Depot.
I have built half a house with these and many many remodeling projects. They have not let me down since.
RIDGID turned out to be a quality tool for medium amounts of work and sometimes more.
When I needed warranty service I just took the tool to my local HD and they sent it off ......... but it did take forever to get it back.Problem with the warranty service is that the location is far from me.
