In my old house I had a Rennai tankless that I descaled myself for about 10 years, so I’m very familiar with the process. However, in my new house I have a Navien 240A2 with recirculation so the process is a bit different.
With recirc there’s a function in the unit’s installer menu to use the integrated pump to circulate the descale solution (in my case white vinegar). The instruction manual is worthless, so I went to YouTube and found a video of a descale of a Navien 210A2. This gentleman hooked up two hoses; one to the service port on the hot output and the other to the service port on the recirc line. However, I only have service ports on the cold input and hot output - nothing on the recirc line. I’ve attached a pic.
Here’s my question; will I be able to descale using the two service ports on my hot and cold with nothing on the recirc? Not knowing the internal workings of the HWH, I’m not sure if the descale fluid will circulate in/out of my bucket using the cold inlet port with the unit in descale mode. Obviously, I would close the valve on the recirc line so it doesn’t run through the house.
