Would improperly installed vapor barrier cause condensation at floor level and therefor cause the bottom 3 to 4 inches of drywall to because brittle/crumbly, and cause the floor to be cold due to drafts?
Backstory:
I bought a 1966 house that needs/needed some TLC. Ive installed new mdf baseboards in most of the house after the walls got a fresh coat of paint. One room to go and Im getting ready to install baseboards and notice the very corner of drywall is crumbling, further inspection reveals minor dampness in the corner (and now a 6x8 hold where I had to cut the drywall away). The bottom of the drywall seems soft but not really damp most of the way along the wall. I also notice that the vapor barrier isn't stapled to the bottom plate (at least in the corner but I suspect the whole length of the wall). If this is the case then I may have to remove the first bit (6-8 inches) of drywall along the wall and staple/(caulk?) the barrier to seal it. Theres no sign of mold, and from what I can tell the insulation behind the vapor barrier is in good condition, but I can only see a very small section right now).
Backstory:
