Let me give a little background and sorry for the length. Last year After spending much more time in my living room w/ my now 1yr old daughter I've noticed how much cooler and drafty the room felt compared to our other living spaces (split level home). After pulling my hair out and ripping the trim down around our bow window (see attached photo's) which I felt was contributing much to he issue and insulating it the best I could with spray foam, caulk, etc.. the problem still existed. The room was just colder, I swear I feel the slightest draft laying on the rug. The rugs itself are cold without a doubt. Anyways I realized 100% after thinking about it (I never said I was smart) & visiting the crawl space that it was the culprit. First off the batts are installed backwards, all the paper is facing down and visible. Also while inspecting it further I see tons of gaps and holes and some of the batts simply not secured between the joists and falling out of the joists and touching the ground. The crawl space is also vented or lets say it has vents, however the previous owner blocked the vents with batt insulation closing off the ventilation. He's even put up some insulation on the cinder block foundation, which I read is a no no for vented crawl spaces. The crawl space itself seems to be in good condition, not much moisture at all in the dirt, pretty dry for the most part throughout, no signs of mold or anything to worry about.
Looking to do the job myself and seeing the work involved w/ reversing the batts and re-installing them buying some new. Spray foam seemed like the quickest, easiest, & air tight solution. My question for the forum is are some of the DIY spray foam solutions I've seen online worth it or any good. Is one more recommended then the other? Besides spray foam would you recommend another type of solution? I've also reached out to some local spray foam contractors to get a price for a pro to do it, but scared to death to see the quote, lol. Thanks in advance
