Converting 50 amp to 30 amp
8.3K views 5 replies 6 participants last post by  HouseHelper
My stove recently broke. The outlet is a 50 amp. My aunt gave me a stove, but it has a 30 amp plug. She says there is a way to just switch the plug. Is that so? And how would I go about doing that?
#3 · (Edited)
Replace the receptacle (outlet; socket) and also replace the 50 amp breaker down in the panel with a 30 amp breaker. The stove cord and plug remain unaltered.
There could be complications. If the plug for the new stove has neutral and/or ground contacts that the original cable to the old receptacle does not provide conductors for, you would need to string a new 6* gauge 3 conductor plus ground cable down to the panel before you can complete the project.
If only a ground conductor is needed and lacking you can string just a ground conductor to the panel more or less following the route of the existing cable.
* 10 gauge will carry 30 amps but it would be nice to future proof the installation for 50 amps for the next owner of the house.
