1 - 3 of 14 Posts
I am late to the party, but when we ran into this we did match the angle of the stairs below. We always gave the closet a few more inches than normal, just because we could.
Then inside the closet most times we would put a step in the floor. so it had two levels.
Yeah I have yet to determine just how much "padding" I need on each side of both of the two doorways in this structure. I'm going to get a professional opinion next time my buddys over.
Does come in 2" increments so 2'4".2'6" and so on.And the framing is 2" bigger than the door. a 36" opening by a 34 inch slab door Bi fold doors are different
You only add 1 1/4"
The stud on the right can be removed if you need more room. You just let the drywall run into the door jam inside.
1 - 3 of 14 Posts
