I have a 13.8V 3A power source. Can I charge a car battery with that?
Yes a real battery charger will have protection circuits, then trickle charge to keep it topped up. That's just a bit lower then what your charger puts out anyways, so you'd be waiting a real long time before you have a problem. As long as you monitor it, it'll be fine.How would I know when it is done charging? I don't want to damage the battery or blow anything up. I think an actual "charger" would have some circuitry to shut itself off automatically.
Hey... Oso.... could you explain equalization charge to me...Repeated charging of a battery with that particular 3amp power supply (not a charger) will lead to sulfation of the plates. The 13.8 voltage is two low for 12v FLA or AGM batteries, particularly in the bulk and absorbtion charge stages. The voltage is much closer to a stage 3 or float charge voltage.
If you don't hit the battery with a equalization charge periodically, it will die sooner than necessary.
