1 - 1 of 18 Posts
Chances are you can re-frame this. You will need new supports for the ends of the header for your opening. If this is on the second floor check to be sure that there is not a support for the existing supports for the header below. Which would mean this is a structural wall and it would complicate matters.
Reaching into the closet corners would be something I would avoid. Maybe a larger opening.
1 - 1 of 18 Posts
