Cement board application direct ground contact
1 reading
45K views 22 replies 9 participants last post by  footholder
I have used it to close up a basement window at ground level with good results. Couldnt think of any other material to use for that application other than solid treated wood.
PVC board works well when the siding might be to close to the ground or in the ground, I use it a lot of times to keep my first roll of siding high enough off the ground. Fiber cement board , Hardie is not rated for ground contact will delaminate.
