I've got this ceiling light with two black wires. From what I understand I'm to put black with black and white with white. How do I hook up this lamp with this outlet?...
The fixture wire has 1 conductor with smooth insulation which is the hot and 1 with ribbed insulation which is the neutral. If you are not sure which is which, don't fret about it, it will still work if you get them reversed.
FYI, the reason there is a designated hot and neutral on a light bulb socket is so, if the switch is on, one is less likely to get shocked if the shell were hot (normally the neutral connects to it) and you touched it changing the bulb. No effect on its operation.
Larger orange wirenuts are ok. I would use yellow.
Related Threads
DIY Home Improvement Forum
posts
3.4M
members
353K
Since
2003
