Carpet to Laminate Floor Transition
5.9K views 7 replies 5 participants last post by  joecaption
Put the transition track right under the door. Put a piece of tackstrip about 3/8" back from the track. Kick the carpet up, rub it down, trim and tuck in. Finish the laminate leaving a gap. Put the transition cap on and you are done. The cap will cover both edges and with the door closed you will only see whatever is on the floor of the room you are in.
