I need to cut a piece of 12"x72" fiberboard short, to 12"x60" long. You know the kind of fiberboards used in lower end cabinet backs and drawer bottoms. Thickness is 1/8".
I have most hand tools and power tools but not sure what will produce the cleanest cut edge.
I was thinking using a utility knife and score repeatedly may work if I can cut the same exact line without deviation and sometimes corners may tear a little.
Than I thought to use my sliding miter saw or circular saw with a 10" blade but it might leave a burn mark (or not?)
I think a jig saw or reciprocating saw or OMT will make a clean even cut even with guides due to the thin board's flex.
I do have a table saw but not sure it will probably be a similar cut like the circular saw.
tin snips will give a jagged edge.
my router is out of commission at the moment.
advice?
advice?
