Best way to add an outlet behind my tv in a wall with metal studs
1 reading
1.6K views 17 replies 11 participants last post by  Thom Paine
Hi all,
I live in a condominium with commercial construction. My walls are supported by metal studs and the sheetrock wall is two layers thick.
Current outlet is on the bottom left of the picture below. I'm looking to add an outlet behind my tv wall mount (or otherwise getting power to my tv without having a hanging cord).
The blue tape marks three metal studs between the existing outlet and where I'd like to pull MC cable. I've checked and unfortunately I cannot find any cutouts in the studs for me to try to fish the MC cable horizontally across.
What are my options? I think they are:
1. Cut lots of holes through my double sheetrock, punch or drill holes through three metal studs and run the MC cable to the new outlet. (I imagine this would be a very messy and time-consuming job.
2. Install surface wiring. Would not look as nice, but would probably save me a weekend of work between drywall patching and painting.
3. Try to run MC cable behind the wall stud. I believe there may be enough room to do this, although it will be hard. But there is some space between my wall and my neighbor's and I might be able to run the MC that way. Not sure if this is up to code though.
Appreciate the help.
It sounds like it might be a firewall. Cut a hole big enough to install the box big screwed to the stud. Maybe put fire protection all over the box. Then seal it up tighjt with mud and tape.
3 little holes take as long to repair as one big hole.
#7 ·
In addition, if the wall is an adjoining wall with another unit, depending on the condo agreement and jurisdiction, it might be considered a 'common element' and require board approval to alter.
#8 ·
Sounds to me also like a possible firewall.
I would not do anything as others have already indicated to you.
You may not be allowed to do any electrical on your own and you may be tampering with a firewall.
Even poking a hole in a stud cavity where an electrical outlet box from the neighboring wall has one could compromise the integrity of the firewall. This would give a path for fire to pass from one unit to the next.
On wall conduit is a possibility but again you have to check to see if you have the right to even work with the electrical system even being in your unit.
#9 ·
In the pic, the guy has all his tools laying there. I'll bet he's already finished the job. LOL
One of those deals, do it and ask for forgiveness. Because if you ask the association they will say NO. (y)
