It doesn't appear to be attached to a spanner bar unless it is molded in. Note no screws or bolts through the base to attach it to a bar. Take needle nose pliers and pry the edges inward. The box will break in pieces until you can see what is up there. If you have a support member, you're good to go with several types of fan rated boxes. We won't know until you do the demo. Post a picture once you have removed the box.
Edit: I see the bar and can make out the rivets you indicate, so it is attached to a bar. Demo is the same. Once the box is removed, the bar can most likely be pushed up until it releases from the sides. Still need that picture, though.
