Beam strength sizes
50K views 16 replies 5 participants last post by  sannitig
So then the 2x8 is stronger than the triple 2x6 beam.
The pdf says the triple 2x6 is stronger
for spf the 3-2x6 beam is stronger than 2-2x8 and for southern yellow pine the 2-2x8 is stronger than the 3- 2x6.
in order for the triple 2x6 to be stronger it has to be nailed in the correct beam nailing pattern and if your floor joists for the deck are 2x8 then a triple 2x6 beam does not work to well.
